I must be going crazy
jnkirk1974
Post by jnkirk1974 »
Ok, I went to start pulling fuses and I cannot locate any fuses that say:
SEO IGN
RDO 1
RAP 2
TBC ACCY
Are the fuses on the '08 trucks labeled differently?
Also, I cannot locate the Onstar fuse(s). I checked the Chevy manual and the Onstar manual as well.
I can't tell if I have the correct instruction manual (maybe the big problem). It only covers vehicles up through 2005).
Sounds like I shouldn't even be messing with this if I cannot even locate proper fuses...........
Predator: U7194
Truck: 2008 Chevy Silverado Z-71 (LTZ)
johan
RE: I must be going crazy
Post by johan »
You only need to pull the fuse for the Navigation system if you have one, no others are necessary to pull on the 07-08 NBS trucks.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
jnkirk1974
Wow, are you sure? Just want to make sure that I understand correctly.....
Unless I have the navigation system (which I don't). No fuses need to be pulled....even if I have Onstar.
Correct?
If this is right (which it looks like you work for DiabloSport), I guess I'm ready to give it another shot.
Predator: U7194
johan
Post by johan »
Correct, the 07-08 trucks are not as sensitive as the old body style trucks.
Diablosport INC
jnkirk1974
Well crap, it's telling me that I have an "Unsupported Vehicle". I'm using the U7194. I guess this means I need to find someone with a PC to download the new update for the 08 trucks? My 08 Silverado has an "M" in the VIN number.
Here's some other helpful information:
My build number is v.8r07 (born 08/10/2007)
Predator: U7194
jnkirk1974
After reading several posts, it sounds like my particular truck isn't and won't be supported, since it has the "M" in the VIN #. Is this correct, even after the latest update?
Predator: U7194
jnkirk1974
Am I dead in the water?
Predator: U7194
U7194 Predator for Silverado(new body style 2007-2008) 4.8L,5.3L,6.0L engine, must have have the 8th digit of the VIN = C, 3, 0, J, K, M, Y or 8
make sure you're up to the latest revision for your Predator, which is 8r10... and can be found here:
http://diablosport.com/index.php?module ... lay&pid=88
johan
Post by johan »
yeah, Lew is right, we added the "M" motor in the r10 revision. Update your Predator to it and you should be good to go.
Diablosport INC
