I have an 07 magnum srt8 with r18 93cai tune on it. Love the predator, but the only thing I want to understand more are the fan settings. My passenger side fan after putting on the tune sounds like it is rubbing the housing and making this noise now. I have never heard that noise before. So I know that this is a problem with the fan but I am wondering why now is the first time I heard it. Is it because that passenger fan has never turned on before or is it because it is now in some kind of high speed setting now after the tune?? So I have unplugged the passenger fan for now untill I have time to unbolt the fans, but mean while can someone tell me if that has happened to them and what they did. And if there are any ajustments I can make with the DS and what they might be to fix this.
thanks guys
Need some help with the fan settings...
RE: Need some help with the fan settings...
What thermostat do you have? If stock you need to raise the Turn on temps. It can be done in the Predator. Raise all the LS ones to 203.xx, and all the MS and HS ones to 226.xx. There are 3 of each.
Well I guess if I would just read alittle on this site I would find the answer to everything LOL Put setting for the temp back to stock setting with 93 tune and everything is ok. I will have to change the 180 stat soon. Just wondering still if anyone has heard of the passenger fan making that rubbing sounds when on high??
Thanks for the quick response Mike.
