U7136---Tire Size Adjust no effect!
xkm121
Post by xkm121 »
My stock tire size is 225/60-R18. I changed to 235/55-R18 tire and I tried to use Predator U7136 to adjust my tire size accordingly. The quick adjust shows that adjustment is done. However, when I was using GPS to log my speed I found that the speedo is still off! My speedo displays 65mph while my gps only detect 63.97mph. I even asked a LEO friend to use a laser gun to help me log the correct speed and it turns out the same.
So what is wrong with this? How come the predator unable to adjust the tire size? Please help me!
My Predator is U7136 using 9r07 firmware. My car is an 08 Dodge Charger SXT.
Thank you!
RE: U7136---Tire Size Adjust no effect!
Because seemingly same size tires aren't the same size. Besides different manufacturers being different, tires expand when they're spinning. Use the actual measurement of the tire and it'll be accurate
Re: U7136---Tire Size Adjust no effect!
xkm121 wrote:My stock tire size is 225/60-R18. I changed to 235/55-R18 tire and I tried to use Predator U7136 to adjust my tire size accordingly. The quick adjust shows that adjustment is done. However, when I was using GPS to log my speed I found that the speedo is still off! My speedo displays 65mph while my gps only detect 63.97mph. I even asked a LEO friend to use a laser gun to help me log the correct speed and it turns out the same.
Thank you!
did you ever check to see how far off it was when the stock tires were there???
xkm121
Post by xkm121 »
Thank you!
Yes. It was right on the spot with stock 225/60-R18 tires.
I dont know why but this function is not working for me.
xkm121
RE: Re: U7136---Tire Size Adjust no effect!
Post by xkm121 »
And it seems nothing can affect it. I went as far as changing it to 255/40R18
Re: RE: Re: U7136---Tire Size Adjust no effect!
xkm121 wrote:And it seems nothing can affect it. I went as far as changing it to 255/40R18
and clicked apply, and did the key cycle?
xkm121
RE: Re: RE: Re: U7136---Tire Size Adjust no effect!
Post by xkm121 »
I did everything the tool showed me to do. It says tire size updated successfully.
I also tried input direct tire height. My tire measures 28.1in so I input 28. No effect. I tried 29 and 27, still the same
4 speed auto?
xkm121
Post by xkm121 »
Yes. My car is 2008 Dodge Charger SXT. 3.5 engine with 42RLE trans.
xkm121
Post by xkm121 »
So no more tech support? Is it because u7136 cant program the tcm part of the 42rle? Come on guys, show some love to the 7136 crowd!
BatmanPPC
Post by BatmanPPC »
I just went from stock to 255/55/18 on my '08 Magnum SXT (v6 3.5L) and entered the size using the predator. Said it accepted. Will need to test tomorrow or over the weekend.
BatmanPPC
Post by BatmanPPC »
BatmanPPC wrote:I just went from stock to 255/55/18 on my '08 Magnum SXT (v6 3.5L) and entered the size using the predator. Said it accepted. Will need to test tomorrow or over the weekend.
OK. This is in no way absolutely accurate as I used my iPhone 4S to determine speed from GPS. The sample rates from apps aren't really high enough to give you instant speed readings but it should give an idea.
I compared to 40 MPH constant for about 1/4 mile on my cluster to GPS and it was pretty much spot on.
BatmanPPC
Post by BatmanPPC »
Question for Mike: When adjusting tire size when tweaking a canned tune, is it supposed to write the tire size adjust right away or wait until I finish tweaking and commit to writing the adjusted tune? As it is now, it writes the tire size to the car right away.
typan
Post by typan »
mikel, when I do my wheel size change with tool u7135 & v.9r28, after applying the change I want & then if I go back to check so if the change did take the tool tells my tyre size is not set, WTF?
