cant change the tune
deputy22
Post by deputy22 »
Went in to change the tune from 91 oct. to Diablo tune and was going to put the backup in and it is saying that the file is corupt and if I try to put in the Diablo tune it gives me a code 4 how do I change this tune or get my stock tune back if I ever need it. Thanks
JonDiablosport
RE: cant change the tune
Post by JonDiablosport »
what tool and vehicle year make model?
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
deputy22
Post by deputy22 »
T1000 2006 chevrolet corvette 6.0 LS2
sjh06002
Post by sjh06002 »
Any word on this? Mine is doing the same, I called and was on hold for 45 minutes and gave up.
wille
Re: cant change the tune
Post by wille »
mine says it's working, as in installing the tune but there"s a problem (ITS NOT). Took it to a dealer had tunes made, There's no difference in TCM regardless from one extreme to the next @ 800.00 so far. Still checking the PCM. Working with Diablo as we speak however for 600.00 you should get a system that is functional a system that you don't have to help them build the software for. I haven't the time to be messing around.
wille wrote:mine says it's working, as in installing the tune but there"s a problem (ITS NOT). Took it to a dealer had tunes made, There's no difference in TCM regardless from one extreme to the next @ 800.00 so far. Still checking the PCM. Working with Diablo as we speak however for 600.00 you should get a system that is functional a system that you don't have to help them build the software for. I haven't the time to be messing around.
are you on the latest update?
wille
Post by wille »
James @ Henson performance set every thing As in up dating as needed. And built some tunes for me as well as installed them with difficulty. So I'd say yes I'm up to date.
wille
Post by wille »
Make, model and year of vehicle GMC 1500 sierra 2011
model # of Predator or Trinity t1000
software revision on the Predator or Trinity v.1r09e
Return to “Trinity GM Gas”
