Original backup gone after software update
glockman49
Just did the newest update yesterday to my Intune. After the update completed I noticed there were no files in my tunes folder and all my log files had left the building as well. So now my original OEM file is gone. Anyone else have this happen?
2012 GMC Denali 6.2
2012 GMC Denali 6.2
RE: Original backup gone after software update
Yes, all my data logs, custom tunes and oem tune Gone! However, I did back up everything onto my pc!!! Also, I restored the oem tune back into my car prior to any updates! So all was saved. The only issue I had after the update was installing my custom tune back into my car. The Intune said it was in it, but during the tuning process no custom tune bar. So I erased the custom tune in the Intune, reinstalled the custom tune from my pc backup into the Intune and downloaded it into the pcm. It all worked!
I highly recommend to do the following:
Back up Everything before installing the update!! Restore oem tune into the PCM prior to updates !!
glockman49
I wish I had followed the same path you did. Fortunately I had a backup of my files on my pc as well. Now I just need to figure out how to put my original OEM file back on the Intune so it recognizes that I have a custom tune installed.
- JonDiablosport
you can not you will have to send us the orignal backup you had from the tool and the backup it takes now and send it over to support @diablosport.com and we will build a file for you to get the truck back to stock. similar to a calibration update done on chrsyler vehicles.
having the original backup from before helps make the process a little faster but it still takes a little bit of time for our engineers to create the file.
so again please send those files to [email protected] and we will get you back to stock so you can use the tool again.
glockman49
I understand about sending you the backup I had of my original file. What do you mean "the backup it takes now"?
- JonDiablosport
yes the backup the tool takes now is good. as we can reverse engineer it to create a calibration update file. to get your car back to stock so you can tune it.
glockman49
so I can send you the backup of the original file as well as my custom tune if needed. How do I get you a copy of this backup it takes now? Currently my truck has a custom tune in it I had Lew put together.
dude im having the same problem...i been waiting on my stock tune all morning. this situation is a big mess
- JonDiablosport
Re: RE: Original backup gone after software update
it does not matter what it is we will take that file and set it back to stockglockman49 wrote:so I can send you the backup of the original file as well as my custom tune if needed. How do I get you a copy of this backup it takes now? Currently my truck has a custom tune in it I had Lew put together.
glockman49
RE: Re: RE: Original backup gone after software update
ok sent it in. Do you need the log file as well?
glockman49
Ok I got the file back from support. Do I just drop it into the tunes folder or what? No instructions on how to proceed??
glockman49... how long did it take for you to get back your stock tune
Re: RE: Re: RE: Original backup gone after software update
Yes, drag/drop it to the intune drive, and then load the cal update to the vehicle.glockman49 wrote:Ok I got the file back from support. Do I just drop it into the tunes folder or what? No instructions on how to proceed??
RE: Re: RE: Re: RE: Original backup gone after software upda
I've done the same thing...updated the inTune without restoring the factory tune...I've zipped up my old and new files, along with both of the XML files...and sent them to support.
you can just let it do a calibration update...
