2010 Dodge Charger 3.5L - Modifying Diablo Tune for CAI + TB
st4rdust
Post by st4rdust »
I've been using the Diablo tune on my 2010 Charger 3.5L and it's been great. My car is stock, so the only paramater that I adjusted in the Diablo tune was the throttle boost - I added 20%.
My next modification will be the intake system - I will be adding an R2C CAI and a 71mm ported throttle body.
What I'm wondering is that, with the engine pulling in much more, and much cooler air, how can I adjust the Diablo tune in order to fully take advantage of the new intake system? Which parameters are ideal to adjust for maximizing performance from an aftermarket intake setup?
RE: 2010 Dodge Charger 3.5L - Modifying Diablo Tune for CAI
Its not pulling in much more or much cooler air. A motor can only use a certain amount of air. By enlarging the throttle body all you're doing is decreasing the air velocity. You aren't actually increasing the air amount at all because the motors air requirement hasn't increased. Only way to increase the motors air requirement is to increase displacement, rpm, or cam it to change the length of time the valves are open and how far they're open. Same thing with an intake, the same amount of air is coming in, its just less restricted. And with a lot of intakes out there, it won't actually be cooler then stock.
st4rdust
Re: RE: 2010 Dodge Charger 3.5L - Modifying Diablo Tune for
Post by st4rdust »
Mike_Levy wrote:Its not pulling in much more or much cooler air. A motor can only use a certain amount of air. By enlarging the throttle body all you're doing is decreasing the air velocity. You aren't actually increasing the air amount at all because the motors air requirement hasn't increased. Only way to increase the motors air requirement is to increase displacement, rpm, or cam it to change the length of time the valves are open and how far they're open. Same thing with an intake, the same amount of air is coming in, its just less restricted. And with a lot of intakes out there, it won't actually be cooler then stock.
My mistake for wording that post wrongly. So are you saying that after adding a larger, ported throttle body and an R2C cold air intake, there is no need to adjust the Diablo tune (or any tune that the car may be set at) because the engine is practically unchanged?
RE: Re: RE: 2010 Dodge Charger 3.5L - Modifying Diablo Tune
Pretty much, yeah, theres no changes necessary. Does the u7136 have CAI tunes? If it does you can just use one of those. If it doesn't, that means that the motor doesn't lean out with an intake and no changes are necessary.
st4rdust
Re: RE: Re: RE: 2010 Dodge Charger 3.5L - Modifying Diablo T
Post by st4rdust »
Mike_Levy wrote:Pretty much, yeah, theres no changes necessary. Does the u7136 have CAI tunes? If it does you can just use one of those. If it doesn't, that means that the motor doesn't lean out with an intake and no changes are necessary.
I'm not familiar with the U7136. I've been posting on this board ever since I bought the inTune which I've been using with the Diablo tune, although I know the U7136 has a Predator tune with similar attributes. I'm not sure offhand if there is a 93 octane CAI tune on the inTune.
RE: Re: RE: Re: RE: 2010 Dodge Charger 3.5L - Modifying Diab
Right, u7136 is the Predator that supports the 3.5. It has the same tunes as the inTune does.
Hernandez
Post by Hernandez »
I have the dodge charger 3.5v6 and purchased thw diablosport intune i1000 for it but I dnt know where 2 start....only upgrade I have a cold intake and daul exhauat and 22inch rims....i plugged intune in and donloaddd the diablo sport tume and set parimeter changed to my 265/35r/22 and set throttle boost to 20% as well (max)....but it seemed to make my car run slower so I tried the octane 91 setting and octane 89 settinh and both seemed slower than atock without chil!...any help please do I ned to adjust dablotune more or keep stock tune and adjust it?
Hernandez
Post by Hernandez »
