Do you have any time frame for implementing the analog inputs logging directly from the Intune? This feature is the only reason I switched from my DSP and the freezing while logging with DataViewer issue is making the whole datalogging process a nightmare.
I am sure I'm not the only one eagerly waiting on this.
InTune Analog input logging
RE: InTune Analog input logging
it is on the short list....
Is there more PIDs available internally with the Intune then with the DSP?
should be a similar list...
I am about to purchase an Intune to also log my AFR.
I assume from this thread that the analog inputs cannot be logged.....yet? This IS going to happen?
Where is the setup screen for the analog inputs?
I assume the 0-5V input can be converted (raw to eng units) to read/display/log any analog min/max range.....like AFR?
Is there a thread where this is discussed?
What is the part number for the adapter?
2006 Charger SRT8
Inferno Red with All Factory Options / Groups
Side moldings and rear ram's head shaved, Diablosport Trinity 2 Platinum, Billett Technology bling
MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
