Question, I have Predator U7146 for my 01 Mustang Gt, I plan on replacing thermostat with a 180. What fan settings would you recommend for high speed and low speed settings.
Dave
JLT RAI, Dragon, Flows, 3.73 gears, FAST Wideband A/F Meter
Fan Setting
RE: Fan Setting
You'll want to set the fans to come on at about the same time as the T-stat opens up.
Re: RE: Fan Setting
So your are saying set both HIGH & LOW fan settings are set the same when T stats opens correct.mikel wrote:You'll want to set the fans to come on at about the same time as the T-stat opens up.
Dave
RE: Re: RE: Fan Setting
If there is a spread of say a few degrees between the settings no, I would leave that spread, basically if you lower one by 20*, lower them all by the same amount.
