we have 2 06 models here, neither of which will reproduce this issue....
2006 Charger Trinity Monitoring ESP BAS Ligth and lots more
RE: Re: RE: Re: RE: Re: RE: 2006 Charger Trinity Monitoring
pics if possible
This is the same problem MSD used to have. Its pin 13. http://www.dashhawk.com/faq.html#dodgeissue
theblackone
Correct, this is what I was going to post.
I had a dashhawk before the trinity, did not have any problem with it. But I did buy it used and pin # 13 is not there anymore so it was probably removed by the previous owner. this is why it was working correctly on my car!
theblackone
Re: RE: Re: RE: Re: RE: Re: RE: 2006 Charger Trinity Monitor
You would have a picture with an empty spot on pin 13. I removed the cable and taped it back on the cable assembly.mikel wrote:pics if possible
Picture of the diagram from the manual shop.
I can't remember if 13 is a white with light blue line or white with dark blue line.
There is certainly different cable assembly in the plug for early 2006 build and late build since pin # 7 is different in early and late build.
RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Charger Trinity Mon
thanks!
Just wanted to also agree that this did fix the problem in my 06 RT charger also. White with a dark blue stripe, #13 pin.. removed that and tested, trinity is now working perfectly.
Does any one know what this wire actually goes to? or what it does? will not having this effect anything else? or any other scans?
