intune.exe issues
PhatBasturd
please open the intune drive and post the info.xml file here, and also tell me if there is an .itfg file on the intune drive, and if there is, delete it
PhatBasturd
Yes there is a Group_Update.itfg
Here is the xml:
<?xml version="1.0"?>
-<tool_info> <main svn="4210" sw_rev="1r01h" full_version="InTune-1r01h 03/29/2012 12:07:10 PM"/> <registration status="0" sn="CIDKXE2-1"/> <restore bc="0" vin="" id="0"/> <db pid="1r01a" tune="1r01c" mfr="GM"/> <db pid="1r01a" tune="1r01a" mfr="DCX"/> <db pid="1r01a" tune="1r01a" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <updates count="2"/> </tool_info>
Here is the xml:
PhatBasturd
sweet, that should be the fix.
- ptperformance
if you post the actual info.xml file, I can both get you the needed cal update, and make you a registration file....autox wrote:I cannot update it because it needs to be registered. or so that says on the display
but i can't registered it because it can't be detected!
[quote="mikel"][quote="autox"]I cannot update it because it needs to be registered. or so that says on the display
but i canSame here please...
inTune worked fine on update 1r01h now wont work at all with 1r01i. And I have never been able to register. I never get a PIN code sent to my e-mail after filling out the reg form.
-<tool_info> <main svn="4599" sw_rev="1r01i" full_version="InTune-1r01i 05/15/2012 10:38:04 AM"/> <registration status="0" sn="CIE8B96-1"/> <restore bc="0" vin="2B3CJ7DW9AH199744" id="0"/> <db pid="1r01a" tune="1r01e" mfr="GM"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01a" tune="1r01b" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <unsupported vin="2B3CJ7DW9AH199744" oem="DCX" calid="68004309AD"/> <updates count="2"/> </tool_info>
- JonDiablosport
the registration screen has been completely revamped with 1r01i. even before it was released actually. and you are posting the contents of the info file not the actual info file. Please choose post reply and attach the info.xml file to the post. thanks;
or email it to [email protected]
what vehicle do you have?
