no... as I mentioned, there is no need to restore the backup first...
just hook the predator up and go to install a tune just like you did the first time... except instead of choosing "Install Tune", select "Modify Tune"... after making your adjustments, click the ESC button a couple times, it'll ask you "Install tune now?" - select YES and away you go! it installs the tune with your adjustments in it...
2007 Avalanche 6.0 VMax - new revision this week?
no problem man - you're welcome!!
B,
To answer your question about what octane the performance tune is for your truck, it is a 93. But around here in MN we don't have much choice on getting 93. I have been running 92 for months without any problems. However, your 6.0L could be differant. Just monitor your knocks when you run 92. If you have any, retard the timming a bit for the 92.
-DOA
-DOA
exactly! ^^^
