speedometer correction
I put 35" tires on my truck and cant find any where on the programmer to change the tire size. I have an 04 superduty with the r19 crom.
RE: speedometer correction
Also after i put the r19 download on my truck the 60hp setting was really upsetting compared to the r17 60 hp setting. It's like a huge hesitation after i floor the gas and even after it gets going it doesn't seem to have the power. Almost a stock feeling. Can u give me some help with this?
This hesitation is not only at a dead stop also while rolling at 30 and 60. Just a longer than stock hesitation and less power than stock also.
I will advise the tuner of the issues you are having on the 60hp tune. Have you had issues with the other tunes as well so I may let him know?
Also, the Predator for your truck does not have the capability for tire size change.
Christy High
lurker.
lurker.
i did have a problem about 2 months ago with my truck. It read low injector pressure control curciut. With bad surging and rough idle. Took it to the dealership and they installed a new I.C.P. senser. Which ran me about 500 dollars! So when i saw the forum saying that the programmer was fixed with a revision i uploaded it thinking it would solve the problem from happening again and having to spend money that appearently didn't need to be spent. As of right now i have it off of my truck because it seems that i have more power and throttle response with it stock. Needless to say i'm very displeased with this tune. The power and throttle response from r17 tune was great. MPG had alot to be desired, but other than it surging and messing up the senser everything else was fine
Batman,
If you'd like I can send you r17 again until the issues you are having with r19 are corrected. Send me an email to [email protected]
Christy High
lurker.
lurker.
I tried to send you an email but had trouble. So i sent you one through my internet service provider. Let me know if you got it? If not send me a message on here and i'll give you my email. But if not i'll take the r17 crom atleast r19 is fixed. Thank you
Thanks for sending me the r17
wenzomatic
Does the new crom for the U7170 have speedometer correction for larger wheels and tires? If not, is there a possibility of having this included in future products or upgrades?
I've got the older programer and 35 inch wheels and tires.
'99 PSD F-350
Cold Air Intake
4' Turbo Back Exaust
'99 PSD F-350
Cold Air Intake
