Not able to use my adjustable parameters, shaded in grey..
RE: Not able to use my adjustable parameters, shaded in grey
please email me the info.xml file from the tool or post it here.
2006RTMagunum
Guys, any help?? Sorry to be a pain but I'm stuck here..... Thanks!
I'm having the same problem!!! Ever since update
holiday weekend guys... they won't be back until Tuesday....
-<tool_info> <main svn="4599" sw_rev="1r01i" full_version="InTune-1r01i 05/15/2012 10:38:04 AM"/> <registration status="1" sn="CIDJZ50-1"/> <restore bc="0" vin="1B3ES66S74D640654" id="0"/> <db pid="1r01a" tune="1r01e" mfr="GM"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01a" tune="1r01b" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <unsupported vin="1B3ES66S74D640654" oem="DCX" calid="05029415AH"/> <updates count="2"/> </tool_info>
Re: RE: Not able to use my adjustable parameters, shaded in
please drag/drop the attached file to the intune and allow it to reboot, then try the process again.2006RTMagunum wrote:OK, I have done a few updats already in the past... It has asked me to register the tool a few times and I cant! I get a window that pops up saying "SMTP error. Function connect failed (104). Come on this seems to be getting worse... Im sorry but I am getting frustrated with this product now.... Why cant I change my setting, why cant I do updates, why wont it let me register the product??
2006RTMagunum
RE: Re: RE: Not able to use my adjustable parameters, shaded
Sorry Mike but I am at a loss here.... I did the drag/drop and let the tool do something but it never rebooted. I unpluged and let it reboot that way and after it was done I got all the same issues....cant I change my setting, cant I do updates, wont it let me register the product....
2006RTMagunum
When I open the intune folder I see the Diablo icon and it says next to it download, I click on it and it says no program to open it. I click on the part where it was let web open and it gets stuck there....
Im not following you.
All you should se on the intune drive is a tune folder, logs folder, and the info.xml file.
There is no diablo icon, or download program.
Are you maybe looking in the Diablosport CD ROM drive?
2006RTMagunum
Yep, I am in the intune drive. I see the three things PLUS now there is a Diablo icon with the word download next to it. It's calling it an internet shortcut?
2006RTMagunum
Wait!! Its doing something... I tried it again but did not do the drag and drop... I downloaded it and saved to the intune... I will keep you posted lol Sorry..
Your Number one Pain in the ass customer
2006RTMagunum
OK.... sigh! It rebooted and said it calibrated but still the Adjustable Parameters are shaded in grey and I can not make changes and I still can not register the tool....
What was it that this download was going to fix/do?
the adj param is not going to work, been trying to say that since the start
pick the tune you want to modify, then it will ask if you want to modify it, and choose the green check, and you'll be taken to the adj param menu.
2006RTMagunum
Gotcha, but what happened to it, why do I/we have to go about it a different way now? Plus, still stuck with not being able to register the tool... It's not the end of the world if I can not register it, just as long as I can do my updates.
Thanks again!!!!
Thanks again!!!!
Re: Not able to use my adjustable parameters, shaded in grey
Would adjustable parameters be available if only tow/haul mode was installed on a 2005 dodge ram 4.7
