Think you nailed it Johan
nah, I've seen them revved harder than that...something else is up, with the TCM file it sounds like.
check for codes?
Guys will the ECU automatically add fuel if it sees a lean condition? Hoping to change the blower pulley this weekend, which will obviously lean out the motor.
I chickened out. Decided to put on the 2.55 instead of the 2.38. Don't want to risk over spinning the blower right now. Maybe in the future.
if your fuel trims are positive at normal part-throttle fueling - which means you're running lean and the ecm is adding fuel to keep the stoich AFR at 14.7, then yes - the ecm will assume you will also be lean at WOT and it will add that same additional amount of fueling at WOT on top of the WOT fueling table...
which is why generally at normal part-throttle fueling, you want your average LTFT's to be at 0 to -3.xxx, so that when you go into WOT, it does not add any additional fuel, so that you can better adjust/predict for what your WOT fueling and AFR will be...
just email the current file to Johan and ask him to set it up for more booooost.Mike_Levy wrote:Guys will the ECU automatically add fuel if it sees a lean condition? Hoping to change the blower pulley this weekend, which will obviously lean out the motor.
