DeltaChip instructions/reference
DeltaChip Support
icybishop
Post by icybishop »
I bought a chip for my ZX2 from a different ZX2 owner. It came with the 3 position switch, cable, and the LED.
What's the process for switching the program? The previous owner said it had a normal 87 tune and a premium tune. I've only read online that the chip is switchable between modes and the led indicates modes, but didn't see any printed instructions or a reference about what the colors mean, troubleshooting, etc.
RE: DeltaChip instructions/reference
There is a reference notch on the switch.
Pointing the switch toward this notch is tune 2.(Red)
The middle position is tune 1.(Green)
Down is the stock tune.(LED Off)
To use the stock tune, the car must be started with the switch in the stock (down) position.
To use the performance tunes, the switch should be in the middle or up position and you can switch between them on the fly.
icybishop
Post by icybishop »
Thanks Mike,
Will this LED be on at all times indicating the position? It currently isn't working in any position, but I think the previous owner mangled the connector so I'll check that out.
Also, as a general rule does Diablo set the 87 tune as position 1?
Not sure about which tunes are where, as the chip was likely flashed at one of our dealers, not here.
I would suggest trying to get in touch with the previous owner to see if he can tell you who burned the chip.
Any of our dealers can get you a replacement LED.
Return to “DeltaChip”
