Latest Intune release here.
Welcome to the Intune Download Page. This page is for manually downloading updates, for your inTune, on your Mac. The first three posts on this page will help bring your inTune up to date.
(note: This post will be updated whenever a new release is made)
This update is specific for your Application.
to see the current versions, go to settings/tool info/firmware info
If you don't have 1r03y, you must load that before 1r04i
- intune-1r04i.itf
- (1.88 MiB) Downloaded 8651 times
- InTune-1r03y.itf
- Load first if your Application line reads "1r03x" or earlier.
- (1.82 MiB) Downloaded 23043 times
Latest tune databases:
These updates are specific to the make/model vehicle you are tuning.
DIABLODCX update is for 2011-2014 Dodge/Chrysler/Jeep vehicles
DCX update is for 2003-2010 Dodge/Chrysler/Jeep vehicles
- ford_tunes-1r02h.itf
- Ford Gas/Diesel
- (16.47 MiB) Downloaded 2208 times
- gm_tunes-1r02q.itf
- GM Gas/Diesel 99-present
- (7.85 MiB) Downloaded 3162 times
- dcx_tunes-1r01f.itf
- 2003-2010 Dodge/Chrysler/Jeep vehicles
- (12.88 MiB) Downloaded 3299 times
- diablodcx-dcx_tunes-1r01t.itf
- 2011-2014 Dodge/Chrysler/Jeep vehicles
- (14.23 MiB) Downloaded 4986 times
- JonDiablosport
additional DBS for VIn etc
Here are the additional DBS/Databases for inTune after the last Update. please load them in series.,
Intune 1r01i
after update go to get cdrom from the intune drive. (if it does not work on a mac download the cdrom 1r01f.
copy and paste the cdrom file on to the blank space of the intune directory.
then after the CDROM is loaded.
You will start to load the DBS . first start with the ones that mike has posted above.
then load the following.
vin_1r01a
DTC_CODES-1r01a.ITF
DBNAMES-1r01b.ITF
GM_PID-1r01a.ITF
DCX_PID-1r01a.ITF
FORD_PID-1r01a.ITF
Intune 1r01i
vin_1r01a
DTC_CODES-1r01a.ITF
DBNAMES-1r01b.ITF
GM_PID-1r01a.ITF
DCX_PID-1r01a.ITF
FORD_PID-1r01a.ITF
- ford_pid-1r01b.itf
- (8.27 KiB) Downloaded 5430 times
- cdrom-1r01l.itf
- (5.41 MiB) Downloaded 6463 times
- VIN-1r01c.ITF
- (5 KiB) Downloaded 5321 times
- DTC_CODES-1r01a.ITF
- (447.17 KiB) Downloaded 5317 times
- GM_PID-1r01a.ITF
- (20.79 KiB) Downloaded 6033 times
- DCX_PID-1r01a.ITF
- (7.89 KiB) Downloaded 6146 times
- DBNAMES-1r01b.ITF
- (1.65 KiB) Downloaded 5272 times
Last edited by JonDiablosport on Wed Jul 25, 2012 5:58 pm, edited 1 time in total.
adammannis
RE: additional DBS for VIn etc
Where can we find 1ro2a for my intune? I'm mAC guy
Re: RE: additional DBS for VIn etc
added to first post.adammannis wrote:Where can we find 1ro2a for my intune? I'm mAC guy
RE: Re: RE: additional DBS for VIn etc
I updated the intune and it says I can not do anything with out registering it. I did that twice. I have a 2010 RAM 1500 5.7L Hemi 4x4 BigHorn QD cab. I have the 1r02a update installed.
go ahead and register, then you'll be able to update.
Thanks Jon and Mikel for your help. I was able to get all the updates and even played with the gauges on it and now have all the KR set up to record the next time I drive. I have been having issues with KR running the Diablo Tune (93). I will record a few logs and send them in via email. Thanks again!!!
make sure you're using GOOD 93 octane gas... mobil, exxon, sunoco, amoco, bp and chevron tend to be the good/better brands... don't use Shell or mom-n-pop station gas!
Re: RE: Re: RE: additional DBS for VIn etc
I have have filled up with Exxon/Mobil and once with Kroger (they get it from BP) gas. over 91 gallons. I still get the KR when running the Diablo tune.06MonteSS wrote:make sure you're using GOOD 93 octane gas... mobil, exxon, sunoco, amoco, bp and chevron tend to be the good/better brands... don't use Shell or mom-n-pop station gas!
RE: Re: RE: Re: RE: additional DBS for VIn etc
have you logged your stock tune?
try it...
try it...
angelito000_1
I register mine thru the product registration and I am still receiving the this intune has not being registered and will not update the dcx_tunes_1r01b_264 all the updates before this file it was able to update. what should i do?Venum29 wrote:I updated the intune and it says I can not do anything with out registering it. I did that twice. I have a 2010 RAM 1500 5.7L Hemi 4x4 BigHorn QD cab. I have the 1r02a update installed.
- JonDiablosport
for the intune you have to register from the device.
Re: RE: Re: RE: Re: RE: additional DBS for VIn etc
You want me to re set back to factory and log it and send it in? What do I need to do to get a good log for you? Drive it hard, or drive normal, or just sit and idle? Let me know, so I can log a good log for you.mikel wrote:have you logged your stock tune?
try it...
RE: Re: RE: Re: RE: Re: RE: additional DBS for VIn etc
No, Im just suggesting that you'll likely see a bit of knock with the stock tune, indicating you need either better fuel, or perhaps have oil contamination in thee intake/pcv.
