when i load the csv files it asked me if it a predator when I say no it gves me a data error , so when I say yes it gives me an adjustment the car runs great but is the right way to set the slope
I'm useing the same download that I used with the predator that I have
reading intune logs for slope adj.
RE: reading intune logs for slope adj.
you're talking about DSLogRedux I'm guessing?? heh...
the popup was probably asking you if you logged with a 7192, 7193, 7195 or 7198 predator right?? it's asking you that because you did not record the Equivalence Ratio parameter in your data log - so it thinks you have one of those model predators - because those predator's could not log the Equivalence Ratio parameter... so, you need to find and add that parameter to your data logs...
I believe it's under the Fuel submenu...
DSLogRedux you are right but can not find Fuel submenu.. are Equivalence Ratio parameter. please advise
