Okay, one more time. How do I adjust this?
I can't figure out how to adjust the fans properly. We went over this once before, and I still can't do it. These percentages and stuff is retarded. Just tell me where to put them, since I seem to have a mental block on it. And how do I adjust the IC Pump so theres no delay?
IC went on Saturday, and now the whole engine bay is hot as freaking hell. T-Stat is on order, so I'll need the fans on sooner and faster and to keep the pump running.
And last thing, do I need to get a 3 bar MAP when I go over 14.7psi of boost? Maybe the car already has one?
RE: Okay, one more time. How do I adjust this?
the fans are % of power vs ECT, so set them to higher values than they are now...if its at 25%, raise it to 50-60% or so, and it will run at a higher duty cycle (speed) at that engine coolant temp.
IC delay set to 0.
I dont believe you need to upgrade the MAP sensor at all....
Return to “Trinity GM Gas”
