Latest Intune release here.
For inTune users who prefer to not use Windows, we'll help you out in your own section.
Venum29
Re: RE: Re: RE: Re: RE: Re: RE: additional DBS for VIn etc
Post by Venum29 »
mikel wrote:No, Im just suggesting that you'll likely see a bit of knock with the stock tune, indicating you need either better fuel, or perhaps have oil contamination in thee intake/pcv.
Well, I have went the so called better fuel route. That has not panned out. I will have the intake pvc checked out. In the mean time, what if any kind of adjustments can I make to the tune either Diablo, or 91 tune to help alleviate the problem?
gargabot
Post by gargabot »
JonDiablosport wrote:for the intune you have to register from the device.
When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?
post or email me the info.xml file please.
achavez71 wrote:Hey I was just wondering if I i still have to wait for an update for the intune to work on my 11 mustang gt
the auto updater will do it for you...
gargabot
Post by gargabot »
Attached is my info.xml file.
BRR
Post by BRR »
Same issue here....
Here's my XML
BRR wrote:
mikel wrote:
gargabot wrote: When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?
Same issue here....
Here's my XML
drag/drop this file to the tool, then you can finish loading the updates.
BRR
Post by BRR »
that did it, it downloaded all updsates even the missing files I had...thanks again!
awesome, enjoy.
NGreen
Post by NGreen »
Can you condense the updates to one post? I'm about lost on what needs to be updated and what is an old update. My tuner is all jacked up with updates now and says my pcm calibration is not supported.
hendy16
Post by hendy16 »
how do you register the inTune from the device itself?
info.xml
when you allow the intune.exe updater software to run, it will prompt you to register.
hendy16
Post by hendy16 »
I have a MAC so I cant run the updater software
hendy16 wrote:I have a MAC so I cant run the updater software
drag/drop the attached file to the intune drive of the tool, and it will be registered :)
hendy16
RE: Re: RE: Re: RE: Re: RE: Re: RE: additional DBS for VIn e
Post by hendy16 »
worked great thanks!
Return to “Mac/Non Windows based issues”
