Problem with Data viewer
craigffb
Post by craigffb »
I'm having a problem with my Data viewer. It will run a saved log from the Predator but I can not select what gauges or parameters I want to look at as nothing comes up in the PID window and it will not run a saved log at all. A saved log causes the viewer to close. I'm using the 3.0.0.14 version of the viewer and have tried both 8r04 and 8r07 versions for the U7191 Predator with the same results. I guess I'm not the only one having problems as there was a bit of talk about it on LS1GTO.com. Are you guys aware of any problems with the viewer?
Live2Ride
RE: Problem with Data viewer
Post by Live2Ride »
Choose just the few parameters you want to log from the list. If you select the whole list you will have poor sampling rates and crash the viewer.
Good luck.
craigffb
Re: RE: Problem with Data viewer
Post by craigffb »
Live2Ride wrote:Choose just the few parameters you want to log from the list. If you select the whole list you will have poor sampling rates and crash the viewer.
Good luck.
I didn't choose just a few before, but I may have just used the short list. I'll try the short list next time and see if that makes a difference.
Live2Ride
Post by Live2Ride »
Good luck.[/quote]
I didn't choose just a few before, but I may have just used the short list. I'll try the short list next time and see if that makes a difference.[/quote]
It may be a pain to scroll through but it's worth it. I've had mixed results with the short list also.
Good luck.
yeah, don't choose the whole list - short list or not... you'll get sub-par sampling rates, and a log of only about 6-10 minutes.
you really need to select the individual items to get a good log.
Return to “Predator Ford Gas”
