2007 Chevy 2500 HD - NEW BODY
JCC
Post by JCC »
I have just ordered a new 2007 2500 HD with the 6.0 (gas) engine. The Chevy website and other documentation say the the NEW body style ( not the CLASSIC version, which is still available to order) has an ALL NEW COMPUTER, different than all previous models. It is supposed to be faster and more precise than before.
Your site indicates that the U7192 model from 2006 will still work for all 2007 Gas Chevy trucks. Does this include the NEW version Chevy as well???
RE: 2007 Chevy 2500 HD - NEW BODY
The Predator you need is the U7194. The 07 Classic trucks are supported by the U7192.
In our testing we found very impressive gains on the new 6.0 engines. 25 rwhp peak and even larger gains in torque down low. Let me know if you are interested, I'll email you a dyno sheet.
JCC
Post by JCC »
Yes, please email the dyno sheet. The specs sound awesome! One more question, though. Chevy acually has 3 different versions of the NEW 6.0 engine. The 1/2 ton version is based on the old 6.0 ( 364 c.i.) with 367 rated HP. The 3/4 and 1 ton versions are a bit different at 366 c.i. and crank out 353 and 312 HP respectively. So, the question is that I assume that they all use the same computer, just with different programming, but will the U7104 work with all 3?
Im thinking you are talking about the new 6.2 motor?
Either way, the U7194 will work with all of them.
Return to “Predator Ford Gas”
