U7131 2006 Diesel Not supported ?
wes1600
Post by wes1600 »
Is there a cal support update for 33525553AW ?
RE: U7131 2006 Diesel Not supported ?
what is the revision on the Predator?
wes1600
Post by wes1600 »
Sorry..v9r.07
I couldn't see a revision on the site that was higher.
wes1600
Post by wes1600 »
Any update on this, Mike ?
Are you sure that calid is correct?
Everything for 06-07 starts with 353, not 335.
If it is 335, something aint right, and it may need a factory reflash....
wes1600
Post by wes1600 »
Ok...I'll tell him. It had a "Smarty" in it, and I suspect they did something weird.
I was going to ask if it had a Smarty, and you are 110% correct, they do something 'weird'....we see this often with vehicles that had been tuned with a smarty, they seem to make up their own calids when they restore to 'stock', if indeed it is actually stock :)
I guess it s a good way to lock someone into using your programmer and your programmer only...cant be good if there was a warranty concern and the dealer wanted to know why the truck has a NON Dodge Calid in it ;)
wes1600
Post by wes1600 »
That makes more sense...thanks, Mike !
