05 lly egr delete
MISSOURI1466
05 lly egr delete
Post by MISSOURI1466 »
i have a predator for my lly and want to install the sinister egr delet. can i shut the codes off with my tuner. they are telling me i have to buy a ppe or do there efi live
MISSOURI1466
RE: 05 lly egr delete
i believe my tuner is a late 05 early 06 how can i tell if it has that option?
what is the revision on the top line of the main menu?
MISSOURI1466
i will plug it in tonight and see.
MISSOURI1466
what version does it have to be?
MISSOURI1466
version 2.0
that will have the EGR options.
MISSOURI1466
WHAT SCREEN DO I NEED TO GET INTO? AND THANK YOU VERY MUCH FOR YOUR TIME
its in the modify tune menu after you select the tune you want to load.
MISSOURI1466
GREAT, THANKS
MISSOURI1466
will i still need to install the fingerstick or will that mess up the tune?
no need for it.
MISSOURI1466
JUST GOT MY ENGINE PUT BACK TOGETHER. DID THE EGR DELETE. INSTALLED THE TUNE I WANTED. AND THERE THERE IS ONLY THREE OPTIONS IN THE MODIFY TUNE. GEAR RATIO, MPH, TIRE SIZE IAM I DOING SOMETHING WRONG
