how do you get a custom tune?
where do i find the info for this?
do i have to data log?
- electricmarquis
RE: how do you get a custom tune?
By your name I assume you have a hemi based vehicle. Try this thread for what PIDS to log for a custom CMR tune.
http://www.diablosport.com/index.php?na ... ic&t=21254
You can find a CMR tuner at this link:
http://www.diablosport.com/index.php?mo ... lay&pid=32
2010 Challenger SRT8
how do you change what pids it logs?
also is a little knk st ok? if not how do i fix it? maybe its the gas i had to use shell last time ....
2009 rt challenger
and its got diablo tune
2009 rt challenger
Re: RE: how do you get a custom tune?
Use other gas, not Shell, also get a catch can if you already don't have one. That may help.H3Mi wrote:also is a little knk st ok? if not how do i fix it? maybe its the gas i had to use shell last time ....
2009 rt challenger
Once you go BLACK.....
RE: Re: RE: how do you get a custom tune?
what stations have better gas?
Exxon, Mobil, BP, sometimes Sunoco
so can the quality of gas cause a little knk st?
Quality of gas will cause ST KR, LT KR, and every other kind of KR. So will oil in the intake manifold, which all Hemis get. Thats what a catch can is for, to catch the oil before it ends up in the manifold.
so im pretty much just getting shitty gas? hard to find a good gas station around here i guess...
is that the only thing that will cause knk st or any of those?
No there are numerous things that could cause it. Anything that causes preignition or alters how the spark ignites can cause knock. Cleaners, carbon, oil, lots of stuff.
how do you find out what is doing it?
and if it is shitty gas would a octane booster help?
and i have a catch can so i doubt its oil
Experimentation is the only way to figure it out. Throw in a bottle of NOS Race Formula booster. Thats the only booster that does anything. If it doesn't reduce the knock then its not the gas. Its something else. May even be false.
what do you mean false? it just seems like its losing power when it does that
does location of oil catch can matter?
False knock is when the computer sees knock and cuts timing, but theres really no knock. Any metal on metal contact can cause false knock, like a rattling exhaust or anything similar.
The catch can should be plumbed into your PCV line. Where you mount it doesn't matter.
Check your breather line between the valve cover and intake tube too. Sometimes oil can be pulled through there. I had to run 2 catch cans on my Jeep SRT8 because it was literally sucking the oil out of the valve cover through that line.
