Lb7 stuck on 120
Kawidude
Lb7 stuck on 120
Post by Kawidude »
Can't get my 03 lb7 to come off of 120 tune pulling trailer N stuff lots this summer wondering how I can get the tune down it just keeps saying unknown error any help be great I had a command start installed this past winter would that be part of the problem
RE: Lb7 stuck on 120
yup, you nailed it, the remote start is most likely the issue.
Anything that gets wired into the factory harness can cause these types of issues...
Kawidude
Post by Kawidude »
Ok so what do I gOtta do to get it tuned back down
disconnect whatever you wired up ;)
torres4400
Post by torres4400 »
im having the same problem with my 02. stuck on 120 and havent installed anything new.
2002 GMC Duramax...108k...tru flo foam air system...straight piped...leveled out with Goodyear 285/75 silent armor...diablosport predator...
low voltage?
what is the error?
what is the revision on the Predator?
torres4400
batteries are good. the error is unknown (). revision v.9r08
got a trailer brake installed?
Any electronics?
torres4400
trailer brake has been in long before the programmer. never had this issue before. but unplugged the brake controller tried tuning once again and nothing.
torres4400
some help would be appreciated. havent been able to tow anything and thats slowing me down at work
I hate to say this, but the issue IS in the truck, not with the tool.
Something is causing it to not be able to communicate.
I'd bet my paycheck that this tool would work fine on the bench...
torres4400
should i force an original back up?
thats not likely to help, what is the revision on the Predator?
torres4400
revision v.9r08
so, the truck has NO other electronics installed?
aftermarket stereo? remote start? etc?
