STFT VS. LTFT
hairytool
STFT VS. LTFT
Post by hairytool »
What is the diference between STFT and LTFT? How does one effect the other? When I adjust the injector slope for LTFT will they automaticly coinside with each other :?:
RE: STFT VS. LTFT
STFT are the short term fuel trims.. those are the instant/live adjustments that the ECM is making right at that particular time...
the LTFT's are the learned fuel trims over time...
adjusting the slope will affect both, but we don't care about the STFT's... need to see what the LTFT's are doing, because that's what the EDM uses to base it's fueling adjustments on.
Jruss
Post by Jruss »
What are the dangers of having the LTFT's out of range?
2006 Victory Red 3LT A6, Magnetic Ride, Corsa Sports and Hall Tech Stinger.
depends on which way they are out of range... the ideal range is 0 to -2... but +2 to -2 is also an acceptable range...
if they are extremely positive, that means you are extremely lean... which means you will also be very lean at WOT... bad
if they are extremely negative, you are very rich... which will contribute to poor mileage, and increased engine load which will also adversely affect your auto tranny shifting...
in either case, it will affect throttle response, acceleration, etc etc...
ssheets
Post by ssheets »
I had postive 8.25 on both banks. I subtracted 8% from my injector slope and 8% from my fuel setting. I thoughts that the way the instructions read...am I going the right direction or am I leaning it out even more?
"Determining long term fuel trims:
Long term fuel trims are an accumulated value of fuel added or subtracted during closed loop operation.
To verify and tune for long term fuel trims, drive the vehicle for 30 minutes or until warmed up, monitor long term fuel trims and get an average value. The easiest way to do this is to get on the highway, enable cruise control and sit at 55mph while monitoring the data. Ideal values should be in the 0 to negative 2 range.
Once you get the average long term fuel trim value:
Positive long term fuel trims For a positive value you subtract that value in percent in the predator injector slope. It is also recommended to lean both fuel tables by the same percentage."
This seems counter intuitive. According tho this I decrease my injector slope to increase or enrichin my fuel ratio. I'll get another LTFT run and see where it is.
Predator GM02 2.12 Ver 6.01
LS1 11:1 CR heads and 2.02" valves
232/234 .600"/.600" 112 LSA cam
Long tube headers ORPs
4.10:1 gears w/6spd trans
http://s238.photobucket.com/albums/ff28 ... tor=bottom
if your average ltft's were 8.25, then set your injector slope to -9%. and i normally leave my PE fueling settings at 0....
I figure, if the ltft's are dialed in and the part throttle fueling is correct to maintain the stoich 14.75 AFR, then the WOT should also be in check now that we changed how much fuel the injectors are spraying...
so, with my ltft's dialed in and getting 0 to -2, I leave my PE fueling settings at 0 - and at WOT, my AFR is 12.6 to 12.8x...
hairytool
Post by hairytool »
My LTFTs were off by 2-3% from bank to bank. Is this normal? bank#1 = 11.28 and bank#2 = 9.52 I subtracted 10% from injector slope and that put both LTFTs in the 0>- 4 range but bank#2 is still 2% less than bank #1!!
05' Chevy Avalanche Flex 5.3L(L-59)
Auto(M-30)2-wd
Mods:
S&B CAI
Pace Setter LTs & ORY
Gibson single Swept side CAT-BACK
4.10 Gears w/ Detroit Tru-Trac & 285/75/16 BFGs
U7193 bios: v.6.01 & Soft/Firm v.2.10
yeah, both banks won't be exactly the same....
if you're at 0 to -4, try bringing up the slope a couple so that you get in the +2 to -2 range...
hairytool
Post by hairytool »
Cool, thanks! Also i noticed that the timing goes above 50deg and stays when reving the engine past 2 grand. It seems like alot to me but i get no KR=0.00%
Auto(M-30)2-wd
Mods:
S&B CAI
ssheets
Post by ssheets »
-8% on the injector slope was too far. I went to -4% and it looks right on. I'm maintaining 0 to +2.34 now.
what?? how'd you get from +8 ltft's and slope set to -8%, to only needing a slope of -4%???
sounds like something wasn't read right or allowed to settle-in/relearn initially....
well, cool... least ya got it figured out....
Jruss
Post by Jruss »
06MonteSS,
Once we finally get everthing in tune, can we forget about the tuner until we make a changes or there is a new tune available?
How offen are you running logs on your vehicle?
ssheets
Post by ssheets »
ssheets wrote:-8% on the injector slope was too far. I went to -4% and it looks right on. I'm maintaining 0 to +2.34 now.
Probably the vacuum leak that was throwing things off.
With Jesse's tune it now runs consistant at +6-8 on the LTFTs. He said not to worry about it and that these are good numbers to work with his OS and tune.
The car runs great and drives almost like stock.
pozzo
Post by pozzo »
06MonteSS wrote:if your average ltft's were 8.25, then set your injector slope to -9%. and i normally leave my PE fueling settings at 0....
I checked my ltfts (05 Corvette) and they were +7 so I dialed in -8. The ltfts were then fine but the AFR at WOT was about 18; very lean. I don't think you can assume that because your ltfts are on target that your AFR at WOT will be in range. I changed the PE to +4 to make it richer but have not rechecked the AFR at WOT yet.
no, your AFR is not 18... You are fine - I wouldn't have changed the PE setting...
it's a known issue with certain vehicles/predators... in the Dataviewer, with your log loaded, go to VIEW > PARAMETER MODIFIERS > EQUIVALENCE RATIO-INVERT.... this will invert the AFR data and show the correct values.
