Lb7 stuck on 120
torres4400
RE: Lb7 stuck on 120
Post by torres4400 »
negative. only has a cb radio, and trailer brakes. disconnected both and tried again. even disconnected both batteries hoping something would reset and nothing.
2002 GMC Duramax...108k...tru flo foam air system...straight piped...leveled out with Goodyear 285/75 silent armor...diablosport predator...
trailer brake is a likely issue, make sure it is fully disconnected from the factory harness, not just 12V.
whitneyrd
Post by whitneyrd »
So is his answer to your favorite question the correct revision? v.9r08? Rick
torres4400
i physically disconnected the trailer brake from the harness personally. still nothing.
what is the exact error message?
torres4400
unknown error ()
I hate to keep saying this, but there has to be something wired up inthe truck, that did not come from GM, that is causing this issue..try pulling fuses?
torres4400
already pulled fuses everything checked out fine. how about diablosport checks the took out for me. haven't been able to change tunes in 3 weeks. I've sent it in before.
torres4400
do u know what the other three fuses were?
the ones in the manual, radio, radio amp, and info.
