So I am running Win 7 on my laptop. When I connect my new InTune and let the device boot and prompt it will not autorun even though those settings are enabled. No biggie.......so...........
I then choose open files from InTune 'E' Drive. I see the executable = Intune.exe - per directions I right click and choose Run as Administrator.
I select that and choose YES when that program wants to take control (window)
Then an error message box pops up and says to Connect InTune First!
If I unplug the tuner USB and re-plug - the whole process starts over and always ends there
Help - I want to finish installing the InTune client
Issue When Selecting InTune.exe - Run / Win 7
asphaltgambler
asphaltgambler
RE: Issue When Selecting InTune.exe - Run / Win 7
BTW ......... I did register the unit here directly instead of remotely because I kept running into this roadblock
please drag/drop this file to the intune drive, then when it reboots, let the intune.exe run and it will auto update.
asphaltgambler
tunes are the same...
bullitt133
Re: Issue When Selecting InTune.exe - Run / Win 7
I just received my InTune and I am seeing this same issue. My PC is running Win7 x64. The above link is no longer valid. Can you please repost this fix if it is still viable.
Thank you,
--Noel
Thank you,
--Noel
this this file.bullitt133 wrote:I just received my InTune and I am seeing this same issue. My PC is running Win7 x64. The above link is no longer valid. Can you please repost this fix if it is still viable.
Thank you,
--Noel
- cdrom-1t01ja.itf
- (5.41 MiB) Downloaded 466 times
bullitt133
Thank you! That resolved the issue perfectly.
I do have to say that the last update (1r01i) took quite a while at the "preparing" stage (roughly 40min). I ended up doing some work on the motorcycle while it completed but just wanted to throw that out there for other to expect.
Thanks again for the quick support!
