Traction control disabling.
When you disable the traction control on the Diablo tune, is it only for the next time you start the car? It goes back to normal once you turn the car off and then back on for the second time. Is there a way to disable it until I want to enable it on my terms?
RE: Traction control disabling.
Probably not because its designed for the dyno only. When you turn off traction control, you also turn off EBD, ESP and ABS.
correct, on a chrysler application,it cannot be permanently disabled without custom tuning...
Can't you just cut it off on the dash,when you don't want it ?
Van Patrick
2010 Challenger SRT8
Furious Fushia
Furious Fushia
Or do the no ESP mod....I have a hidden toggle switch and it turns it off completely until i want it back on.
The LXforums has a pretty sweat write up about it...Look up NoESP mod
2006 Charger RT, MOPAR CAI, SRT udp,SRT timing set, SRT headers, mid-pipes w/ Borla CAT BACK, 300 SRT 20's powder coated black, R1 SLOTTED rotors, SRT suspension
Re: RE: Traction control disabling.
You can indeed turn a part of it off, but not the whole system via the Esp button in the dash, it will leave abs and other system working, there is many way to really disable these features 100%, some can use the holding technique, some use tuner, such as the InTune, some will use some kind of ignition switch metod. Easiest and most reliable would be the use of a DiabloSport tuner Imo.vanp5037 wrote:Can't you just cut it off on the dash,when you don't want it ?
2006 Chrysler 300c Awdsome
Intune I-1000
Afe Stage 2 CAI
Billet Tech Catch Can
Egr Delete
Corsa Sport Cat-Back
Tranzformer
Coolit
noESP
JBA Catted Mids
Intune I-1000
Afe Stage 2 CAI
Egr Delete
Tranzformer
Coolit
noESP
JBA Catted Mids
