error codes
rum1972
error codes
Post by rum1972 »
I loaded a custom tune and here are the error codes i get.
p2104 throttle actuator control system forced idle
p2112 throtle actuator control system stuck closed
I reloaded the stock tune so i couid drive the car again. any experience seeing these codes. Should i assume there is a problem with the tune.
Phil
RE: error codes
Post by Phil »
Since you say you are installing a custom tune. Have you replace the throttlebody on this vehicle ?
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
rum1972
Post by rum1972 »
yes i replaced the throtle body with a BBK twin 62mm.
draykas
Post by draykas »
I ran into same problemwith my BBK throttle body Get with bbk and they will send instructionson how to adjust the signal to read throttle position correctly
2006 Mustang GT C&L Racer Intake Kit
Motoblue UDP
BBK 62mm throttle Body
rum1972
Post by rum1972 »
Well i called BBK and did finally get someone to answer and was transfered to technical support which was yep another computer that just said leave a message. I found on there website about adjusting the gold bolt on the throttle body. do you by chance still have the instructions they gave you. I am not holding my breath that I will get a call back from BBK. as always thanks for any help you can provide me.
Return to “Predator Ford Gas”
