Hi i have a 2010 ram 1500 with 5.7 and have been running the 93 oct tune.
Is there any way you guys can help me with removing this torque management. It is really killing me at the track
I have posted my last tune any help would be greatly appreciated.
Thanks.
Torque Management HELP!
RE: Torque Management HELP!
Any help please. I have contacted at least 12 of your custom tuners listed by your website and none of them can be bothered with my request.
If you guys cant help me, can you point me in the direction of someone who can.
Thanks.
Thanks.
I dont think TM is holding you back, why do you assume that?
At full throttle my truck just crawls off the line until second gear then it just takes off with a lot of shuddering.
If the tires are spinning then the traction control will cut throttle. Could also be a converter issue.
I cant even spin my tires.
what fuel do you run?
stock wheels/tires?
any other mods?
stock wheels/tires?
any other mods?
I am running 93 octane.
22" srt10 wheels (same issue with stock 20" wheels.)
85mm throttle body.
vararam ram air.
180 t-stat.
Diablo sport catch can.
Sonnax tranny line pressure booster.
Clutch fan delete.
FYI the shudder was always there since truck was new, leading me to suspect TM.
85mm throttle body.
vararam ram air.
180 t-stat.
Clutch fan delete.
Do you know how torque management works? The PCM pulls timing right before a shift to ease abuse on the transmission and to make shifts feel smoother.
2012 Ram 1500
Kahler
If you have a shudder, under a load, or during a shift. Change the fluid. Moisture will cause that issue. Unless the clutches are bad in the pack. I personally had the problem with water in the trans fluid, and it dont take much either (microns).
At one time the a/c condinsate would run onto the trans where the fill tube/dip stick is or used to be and the o ring would let moisture in over time.
Just thought id throw that at ya.
Re: Torque Management HELP!
*Update* Dodge has a TSB for this issue. I had them reflash my computer with this new update and it helped, now about 80% of my shuddering is gone and tranny dosent hunt as much.
09-10 Ram TSB# 18-011-12
2011 Ram TSB# 18-027-11
