Is there a 87 octane tune on the predator?
Cheddarbob
Post by Cheddarbob »
Is there a 87 octane tune on the predator? or do I have to pay for one. It say for use with 91 octane.
cole
Re: Is there a 87 octane tune on the predator?
Post by cole »
Cheddarbob wrote:Is there a 87 octane tune on the predator? or do I have to pay for one. It say for use with 91 octane.
Depending on which predator you have, most of the current predators have 87,91,93 octane tunes. The higher the octane the more performance can be achieved. We will need to know what vehicle application you have to get you more information on the 87 octane tune.
Cheddarbob
Well I have a 2000 mustang v6
U7146 is the predator that I have
RE: Re: Is there a 87 octane tune on the predator?
This too does not have 87 octane tunes.
Cheddarbob
Re: RE: Re: Is there a 87 octane tune on the predator?
mikel wrote:This too does not have 87 octane tunes.
is there a way to get a 87 tune
RE: Re: RE: Re: Is there a 87 octane tune on the predator?
Using the modified parameter section of the tool, go into the 'global MAF curve' parameter and subtract 12%.
This will allow you to use the tune with 87 octane fuel.
Cheddarbob
thanks
Cheddarbob
ok i just tried to do that and i dont have that option.
Is it listed as global timing? That would be it if so.
Cheddarbob
ok ill try again
Cheddarbob
ok I still cant do it. so here are the option that it says under modify parameter
1 Axle Ratio
2 cooling fan
3 OBDII
4 Idle rpm
5 rev speed limt
6 shift points
7 shift preasure
8 spark advance
9 torque modulation uplash
10 WOT fuel
thats all there is no global timing etc
where would it be or is there another way to fix it
check under the Spark Advance menu - that's your timing....
and hey, at least you have tranny options!! :lol:
Cheddarbob
ok i will check
Cheddarbob
ok i went under spark advance
there is these
1 spark advance 2k-4k
or
2. spark advance 4k-7k
which one do i want
thks
if you only have the 91 Octane tune as your lowest available in the Predator, and you want to run 87 Octane, you'll probably need to adjust/remove some spark/timing in both RPM ranges.
Return to “Predator Ford Gas”
