Predator u7136 Update Corrupt
I plugged my predator in and ran the 9r07.crom update, everything says it was successful but when the predator reboots it tells me the app is corrupt or missing. Any suggestions on how to fix this?
Re: Predator u7136 Update Corrupt
Redo the update. You'll probably have to connect using Legacy Connect and choose what port its connected to.
I erased the update and redid it and reloaded it to the predator also, same error, app is missing or corrupt.
try redownloading the file from our site?
@MIKEL, I did, thats what I meant by I erased it and redid it. Same outcome.
try the file I just emailed you...
I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
Thank you,
Jason
attached.jlcolvin wrote:I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
- u7136-9r07.crom
- (929.66 KiB) Downloaded 762 times
That fixed it, thank you very much.
I am having the same issue here but when I am at the ds downloader app and is at the middle of the prosess downloading I get a error message that says I did not se the tool in the selected serial port, is the tool connected, is the serial port connection correct, is the tool powered up and waiting an the main menue screen....the tool Is connected to my pc and its powered...help please....mikel wrote:try the file I just emailed you...
sounds like a possible bad USB to serial cable issueomaralz wrote:I am having the same issue here but when I am at the ds downloader app and is at the middle of the prosess downloading I get a error message that says I did not se the tool in the selected serial port, is the tool connected, is the serial port connection correct, is the tool powered up and waiting an the main menue screen....the tool Is connected to my pc and its powered...help please....mikel wrote:try the file I just emailed you...
