Predator u7136 Update Corrupt
angcor02
Post by angcor02 »
I plugged my predator in and ran the 9r07.crom update, everything says it was successful but when the predator reboots it tells me the app is corrupt or missing. Any suggestions on how to fix this?
Re: Predator u7136 Update Corrupt
Redo the update. You'll probably have to connect using Legacy Connect and choose what port its connected to.
angcor02
Post by angcor02 »
I erased the update and redid it and reloaded it to the predator also, same error, app is missing or corrupt.
try redownloading the file from our site?
angcor02
Post by angcor02 »
@MIKEL, I did, thats what I meant by I erased it and redid it. Same outcome.
try the file I just emailed you...
jlcolvin
Post by jlcolvin »
I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
jlcolvin wrote:I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
attached.
u7136-9r07.crom
(929.66 KiB) Downloaded 760 times
jlcolvin
Post by jlcolvin »
That fixed it, thank you very much.
omaralz
Post by omaralz »
mikel wrote:try the file I just emailed you...
I am having the same issue here but when I am at the ds downloader app and is at the middle of the prosess downloading I get a error message that says I did not se the tool in the selected serial port, is the tool connected, is the serial port connection correct, is the tool powered up and waiting an the main menue screen....the tool Is connected to my pc and its powered...help please....
sounds like a possible bad USB to serial cable issue
