7193 TM on off?
PowerPhreak05
7193 TM on off?
I am confused. What does toggling tm on and off do on 7193? I have read other posts saying that a trinity is needed to disable tm.
Re: 7193 TM on off?
it allows you to disable the torque management on upshifts.
PowerPhreak05
Re: 7193 TM on off?
And turning that off and turning up shift pressure at the same time can wreak havoc on the trans correct?
Re: 7193 TM on off?
no...?
PowerPhreak05
Re: 7193 TM on off?
So having the upshift reduction turned off cannot hurt trans? Even when pulling? I just want to make sure I'm not cuasing damage with inexperiance.
PowerPhreak05
Re: 7193 TM on off?
Still hoping to get a response to my question about tm. I know you guys are busy and i appreciate any help i can get. What are the concerns with turning off the tm? What kind of trouble can i get myself into with that? Should it be left alone? What are the positive results if any? Or am i just better off messing with the pressures and the shift schedules?Looking for crisper shifting and throttle response. Thank you for taking the time to help. Just trying to understand the processes and results without destroying something i can't afford to fix.
Re: 7193 TM on off?
well, I mean, the TM is there ot protect the trans, and turning it off leave no torque protection in place. Now, do you think your truck is making a bunch of torque, not likely, so it should not be a concern. Throw a blower into the mix, and you'd go through the trans in a heartbeat...
PowerPhreak05
Re: 7193 TM on off?
Thanks for the answer! I turned the tm off and turned the shift pressures back to the preset levels and love the way the shift feel is. Seems to be a little punchier too...
Re: 7193 TM on off?
good to hear, glad you are enjoying it!
