sts twin turbo
franc2
sts twin turbo
Post by franc2 »
Hi I have a 2010 300csrt8 with sts twin turbo with 20 gph progressive water methanol injection, boost is set to 8 lbs. the shop I have used installed the basic sts tune via the predator, as well further tuned using cmr soft wear. I have 2 problems that we can't seem to get remedied.
1. There is wot run on that occurs intermittently, more so after a pull from a dead stop.
2. During the pull from a dead stop there is a hesitation at 60 mph that last 1-2 seconds. I don't think it is transmission slip as the rpm says the same (5000) then goes again. The boost stays constant and the A/F stays the same.
Any suggestions... Thanks Brian
Re: sts twin turbo
1. Its in the tune....
2. Not sure about that, but if you say rpm stays the same, and it stops pulling, it should be evident in a datalog as to what is happening there...
Return to “General Questions”
