Torque Management and Spark Knock Questions
Bossy70
Post by Bossy70 »
I first loaded the 87 octane tune from the Trinity. I heard spark knock, logged it, and it showed a good bit of knock retard. I can try this again and send you a plot if you are interested. Shifted pretty hard, felt like torque managment was disabled, but I did not log that spark parameter. I want to do some more testing later because it seemed I had more power, but I was suprised at how much knock I got with the 87 tune.
I then datalogged the stock tune and it showed knock retard, so I started taking a slight bit of timing out (from stock tune!) and barely added richness (even though I though AFR looked fine).
I then tried to disable the Torque Management (selected "OFF" on the Trinity for "Upshift TM ON/OFF"). It didnt seem to shift as hard as the 87 tune did.
Datalog showing TM is still taking out timing. I attached my most recent tune and log. Can you please check it and let me know.
2010 Chevy Tahoe 5.3
87 octane fuel
ModifiedStockTune.zip
(3.79 KiB) Downloaded 199 times
T03.LOG
(200.87 KiB) Downloaded 215 times
Return to “Trinity GM Gas”
