2009 Silverado 6.2L
Re: 2009 Silverado 6.2L
weird, checking it out now.
Dr.Beardface
Any progress being made?
should be added here.Dr.Beardface wrote:Any progress being made?
- GM_TUNES-1t01mb.ITF
- (4.59 MiB) Downloaded 164 times
Dr.Beardface
That did the trick. Thanks for all your help!
Dr.Beardface
Ok so I'm gonna continue to be a pain in your butt and say that there doesn't seem to be TCM/tranny support. It doesn't create a TCM/tranny backup file either. The ECM tuning works fine, I have it installed right now and was able to change things on it.
- info.xml
- (613 Bytes) Downloaded 138 times
closed.. they'll be back on monday...
Please drag/drop it to the intune drive, let the tool import it, and it will allow you to tune your truck.
- GM_TUNES-1t01md.ITF
- (4.63 MiB) Downloaded 151 times
Dr.Beardface
It's still not working. The ECM tuning works fine but there's nothing at all about any TCM/tranny info.
When I download and install this latest file, I can tune just the ECM. When I install this latest file and then update the inTune, I'm back to having an unsupported vehicle when I plug it into my truck. I installed this file again after updating and I can still tune just the ECM, no TCM/tranny. It seems like this file and whatever that update is are overwriting each other depending on which one was installed most recently. Don't know if any of that helps at all but thought I'd share.
Dr.Beardface
Hey Mike, did you see this?
please post your current info.xml file here
Dr.Beardface
hmm...checking it out.
Dr.Beardface
Any luck with that tune?
sorry for the delay, attached here.Dr.Beardface wrote:Any luck with that tune?
- GM_TUNES-1t01me.ITF
- (4.67 MiB) Downloaded 136 times
