tune wont work from pred to trintiy
msmechanical
Post by msmechanical »
hey guys ,
have a 06 5.7 400ci that ran fine
i upgraded blower to a V7
return fuel system
upgrade to a trinity
NOW THE UPDATE SCREWED ME , the predator had a AJ file now it went to a AL file and the tune cant be used,
created a new file using NEW original backup file. Tried to copy everything one by one and map kpa was 3327kpa at key on, GRRRRR
any help wuld be appreciated
why did updating to trinity screw me, ???
Re: tune wont work from pred to trintiy
The reason it doesn't work is because the tune is linked to the CalID, and it sounds like you updated the CalID. Post the tune and the backup and they'll update it.
msmechanical
yeah the vehicle had to be updated, thanks man,
pcm_04896600al_mm1.drg
this is what i started just to get map kpa right,, reads 3327kpa at key on lol.. so i put a 2 bar mopar on in
(46.65 KiB) Downloaded 151 times
04896600AJ_toon_002_mm14.drg
this what worked with predator,, NOTE IT HAD A HALTECH 2 bar in it,
(46.86 KiB) Downloaded 140 times
in these cases, simply make a cal file of the tune, then open the new backup in cmr, and apply that calfile, to make a copy of the same tune for the new calid.
I'll post it up for you in a second.
OK, neither of those files are stock...whats the deal?
