So I got my truck back today, lifted, big tires, last thing to do is plug in my updated (brand new) intune.... connection went easy to truck, plug in the intune gently and no lights or nothing.... 2 secs later a little smoke from the connection to the intune and it's done.
Whats up with this thing? I bought it brand new like 2 days ago and it smokes the connection.... anyone else had this?
Heres a good one....
Re: Heres a good one....
sounds like maybe the connector got damaged at some point and caused a short.
We'll fix it asap or you can see if the retailer can swap it out for you.
Well thats just awesome, I'm going to see the retailer this am, a very good local place. I'll post up results.
Has this happened to a few of em? I'm concearned that I will be good for the first couple tunes with a new one then have that connection pile up on me later?
Thanks!
Thanks!
If you send it here it wont happen again for sure, if they can swap it out, ask for one with a later date code on the box
Ok thanks. So by that I'm hearing the ones saying 05-12 and earlier are prone to this.
Got it replaced this am and good to go.....
But when I run intune.exe it freezes and tells me error code 12007?
Any advice now how to get this thing running?
- info.xml
- (292 Bytes) Downloaded 151 times
Maybe getting some where....
New info file attached.
But when I plug it in it says VIN database error.
Cant beleive I have to do all this manually? Something up or is this normal??
- info.xml
- (270 Bytes) Downloaded 156 times
Gr8WytNorth
Sounds like you are on the same path as my 300SRT8. Just keep going back and forth from PC update to your truck. Should take 3 trips if I remember to get the updates for the vin right. You sound like 2 are done, so just once more and you should be fine. Once it connects, it will be fine every time after. I've plugged mine in a few times to play with things. Works like a charm.
Well its tuned...
I cant believe how much crap we have to do to make these work the first time.
I truely hope I was doing it wrong.
Erickson5006
Nope, it takes a lot of manual setup to get these things working. Diablo released a few batches of them before they were ready.
