Will u7194 work for 2012 silverado?
darkZ
Post by darkZ »
Re: Will u7194 work for 2012 silverado?
would depend on what revision it was on.... but you should get an intune or a trinity... the predator's were discontinued many many months ago...
darkZ
Post by darkZ »
My u7194 is stuck on installing bootloader. It had 9r07 and I'm trying to install 9r31. It's stuck on installing bootloader.
How do I fix this problem
k.. that is an olllld version 7194 that can not use the newer, bigger crom revision update files... so no, that 7194 will not work for your 2012 truck....
darkZ
Post by darkZ »
How do I fix this problem? Do I have to install an older version to make my u7194 work?
If so how do I get this version?
this is the highest/last crom revision update you can go to with that version 7194... but still won't have 2012 support...
you'd need to get an intune or trinity for your new 2012....
u7194-9r10.crom
(960.68 KiB) Downloaded 307 times
darkZ
Post by darkZ »
I actually have this for my 2008 Z06.
I purchased a trinity already. I wanted to update the u7194 with the latest update 9r31 but its stuck on installing bootloader. Just wanted to see if it would work on my 2012 silverado. How can I fix the problem I have with the u7194? Is an older version software I can download to fix this problem?
I already posted it in the post above yours man....
darkZ
Post by darkZ »
Yes i read previous post and I am trying to install the software. But my u7194 will not go pass installing bootloader.
what is the fix to this problem?
you're trying to update it with that 9r10 crom file right? and it's giving you that error still??
that I'm not sure about then... give tech support a call tomorrow....
