intune problems
kcards04
intune problems
Post by kcards04 »
I recently just bought a intune and had some major problems after installing the 93 octane tune on my 05 5.7L hemi grand cherokee. I then disconnected my battery for a few minutes to reset the whole system which was the only thing that helped my vehicle at all. I'm really on the iffy side of trying to install a different tune or just sending it back to get my refund. Has anyone else experienced this or have an opinion on things?
Re: intune problems
what was the problem?
How does it run with the tune?
561-908-0040x4
kcards04
Re: intune problems
Post by kcards04 »
The tune didn't seem to work at all. My jeep had no throttle response at all, the shift points seem to be around 3000-3500 RPM's for every gear, and there was a major shaking when slowing to a stop while actually cutting of sometimes. I talk to tech support yesterday on how to fix it but I haven't attempted to try again seeing how I'm afraid it's just going to happen again.
Re: intune problems
sounds like it may have been on a really old firmware, and needs to be updated.
561-908-0040x4
kcards04
Re: intune problems
Post by kcards04 »
Every time I plug it in to the computer it says software up to date
Re: intune problems
Its not the firmware. Its the 05 MDS, not knowing which mode its in. This happens on a lot of 2005 Hemis. Disconnecting the battery resets the MDS system so it knows whats going on.
kcards04
Re: intune problems
Post by kcards04 »
I disconnected the battery for 5-10 minutes and reset the jeep and it fixed all the problems I had with it, but is there a way to fix this so that the intune will work for my jeep?
Re: intune problems
The problem should only happen after a program is installed. Once you reset the system after the install, it will be fine. You can use the inTune without any issues.
kcards04
Re: intune problems
Post by kcards04 »
I'm sorry to seem a little ignorant on the subject but I'm new with this thing. So are you saying I can install the tune I want then if the vehicle kind of has problems then disconnect the battery and after connecting it again it should work with the correct tune settings?
Re: intune problems
Yes. If you have the rough running and stuff after installing the tune, just disconnect the battery for a while. When you reconnect it, everything will be fine and the tune will be installed. You may not have to disconnect it, so check after you install the tune.
