Ahem...OK...TCM support anyone???
I have another question about the WOT shifting particularly when downshifting from 6th to 4th/3rd. At highway speeds downshifting from 6th to 5th is fine and driving around town the part throttle downshift is also good between all gears. It's just at WOT it seems like it revs up, slips a little (kind of like the stock shifting) then the rpms drop a tad, then it hits the lower gear. It doesn't feel like the shift is too hard, just not a quick transition bewteen gears. I have it set to the firm shift setting and the 87 Diablew tune. Can you take a look at this log I did and see what you think. I did a couple of WOT bursts at 1:20 and 5:55.
No...we have not had a chance...
- bulletpryor86
TCM not supported
I don't think my TCM cal. id is supported, just updated to v.r09d, made some changes to the TCM but when uploaded to truck only the PCM was programmed the TCM reads original backup. Will someone look at this please?
RE: TCM not supported
we'll get it added
- bulletpryor86
Any update on adding my TCM?
will be in the next update.
Re: Ahem...OK...TCM support anyone???
I have the latest TCM tune on my '11 CTS-V Coupe, when it I force shift (sport mode) down to 1st it shifts with a aweful lurch and shudder. I have reloaded my stock tune , drove the car some then updated the trinity and tuned the TCM again....same condition. With the Oem tune there is no issues...any ideas ??
Riderover (Brandon)
Riderover (Brandon)
Re:
Just wondering if you guys have added anymore TCM parameters in the new CROM?fernanbfg wrote:Mike,
Do you guys intend to add more TCM functions like part throttle shift points mph or rpm? Lew pretty much has the PCM tune dialed, just trying to get the shift points dialed in now. It seems like there are way more aptions in the Predator, at least for the 4 speeds.
