Those having issues with Ford diesel tools
MikeWDiabloSport
Post by MikeWDiabloSport »
For those having problems with U7170 or U7165
can you provide the following info:
Model year of truck
Current CalID (Predator will tell you what this is. Options : Troubleshooting : Show CalID Predator needs to be connected to the vehicle to do this)
Issues you are having
rtprestw
RE: Those having issues with Ford diesel tools
Post by rtprestw »
Cal ID is VXCF5H5, Serial 2000693, Part U7165pcm_6_0, 100HP tune.
4-6 mpg drop in fuel mileage, strong diesel odor at idle (not there with stock tune), not as much power and fun as it used to be. Truck has a 4" MBRP exhaust, cat removed, AFE Pro-Guard7 cold air intake system and Accufab elbow. I have thought about going back to r17 and dealing with the low FI code but did not know if it was possible... I would like to have the performance back and if it breaks I'll fix it one way or another.
bcraft
Post by bcraft »
calid vxap2n2 Truck surges or flutters at 15lbs of boost and up. low end and up to 15 lbs truck feels fine. The truck also runs fine with original tune.
I have tried the r19 and 2 different custom tunes. the only mod to the truck is a turbo back 4" exhaust
u7165 03-6.0 f250
thanks,
Brian
jsavelli
Post by jsavelli »
My serial is 20006c4 part u7165pcm 6-0 version v.8r19 calid vxcf5h5. 2006 F250 Diesel. Read past forums and you can see what problems I have been having
MikeWDiabloSport
excellent guys, thanks.
This is the info I need.
Keep it coming.
07f250
Post by 07f250 »
Mike, 07 F250 6.0L, U7165;Calid VXCF5H5, K&N cold air kit, MagnaFlow 4" cat delete. 10,478 miles
40hp (towing tune) strong exhaust smell at idle along w/smoke at start up, surging at 50-60pmh 3-5mpg loss
60hp strong exhaust smell at idle along w/smoke at start up, soot and oily reidue on rear quarter, surging at 50- 60-mph, 3-5 mpg loss.
100hp- nothing happens= stock tune
Techline= needs serious overhaul!
MikeWDiabloSport
After a quick initial review of some of the files, I do see some issues.
Won't take too long to resolve them. I'm going to work to get you some things you currently don't have now.
I'll keep a progress report so you can follow what we are doing.
Treestand72
2003 6.0 VXAP2n2 u7165 lastest rev
Post by Treestand72 »
Have the surge at 60hp and 100hp. Not sure about the boost psi but the surge shows up at about 2500rpm's. The 100hp is down very low on power and will not even spin tires. Both the tunes sugred on the last rev and the newest one and even four custom tunes. Been waiting for a fix back before May.
iwantmorepower
RE: 2003 6.0 VXAP2n2 u7165 lastest rev
Post by iwantmorepower »
Let me try to understand this. For 6-7 months now we have been asking for a fix and now after 4 posts you tell us that you see the issue's and and it won't take long to resolve them. So why did it take 8 months to tell us this ?
jsavelli
Post by jsavelli »
They seem to be only worried about the new 2008 and us old guys are just that....old news!
dieseldoug
Post by dieseldoug »
2000 6speed manual 4x4.......7170 128k.....very bad throttle surge or "flat spot" in the go pedal......60,85,100 tunes all drive thris way ....40 hp tune is the only one that is linear but it doesn't have much nut......truck actually has more acceleration at 1/4 throttle than at 1/2 or 3/4.......not linear at all an very noticeable to all who ride or drive........fuel mileage is good and smoke is minimal ( unlike that 8r01)
dieseldoug wrote:2000 6speed manual 4x4.......7170 128k.....very bad throttle surge or "flat spot" in the go pedal......60,85,100 tunes all drive thris way ....40 hp tune is the only one that is linear but it doesn't have much nut......truck actually has more acceleration at 1/4 throttle than at 1/2 or 3/4.......not linear at all an very noticeable to all who ride or drive........fuel mileage is good and smoke is minimal ( unlike that 8r01)
Doug, are you running 7r19dz?
MikeWDiabloSport
Re: RE: 2003 6.0 VXAP2n2 u7165 lastest rev
iwantmorepower wrote:Let me try to understand this. For 6-7 months now we have been asking for a fix and now after 4 posts you tell us that you see the issue's and and it won't take long to resolve them. So why did it take 8 months to tell us this ?
Because it was just brought to my attention just last week.
It escalated to the point where I was notified of it, so I did some research into what the issue was. Looked at a few files and saw some problems.
If you don't think we are serious about the 7.3/6.0, we removed the main person responsible for the tuning on the U7165. He is no longer with the company.
Mike Wesley - President
DiabloSport Inc.
MikeWDiabloSport
jsavelli wrote:They seem to be only worried about the new 2008 and us old guys are just that....old news!
The 6.4 is important, you are correct about that. But the 7.3/6.0 are our 'bread and butter' tools. I personally drive a 7.3 and know quite a few people with 6.0's. The need to work as advertised, so that is what is going to happen.
We've only owned the company for 8 months and there is alot of work to turn around previous practices
jsavelli
RE: Re: RE: 2003 6.0 VXAP2n2 u7165 lastest rev
Post by jsavelli »
Thankyou for responding, I wish you luck in the getting things turned around. I have been a customer for sometime a will wait to see what happens shortly. thx
