CAL_ID FBBT057
niko
CAL_ID FBBT057
Post by niko »
Hello Friends have a little problem.... i update mi predator U7140 and now when i connect obd in my car exit this: Your veicle is not in our database.contact your dealer for a free update. your CAL_ID is "FBBT057"
My car is a 2005 Mustang V6 base
info tool:
serial: 900a831
Part: U7140 Stang05
Version: V9.9r03
hardware: univ-rev2
bus: Can
Born : 02-26-2010 13152
Bus test: +
please help me :lamer:
Re: CAL_ID FBBT057
you need to update that tool to the latest revision.
niko
Re: CAL_ID FBBT057
Post by niko »
I did update as recommended and now my car in the shop with empty unit without map inside, predator does not know cars and car died! Ford has solved only problem with new remapping original problem returned .... you spoke Monday with my friends of the problem in Italy .... Remember this? We also forced to restore original backup with tails but no result, what can I do with this predator erases memory? I groped a few test on pc? :crashing: thanks MIKE
Re: CAL_ID FBBT057
you can send me the pcm and I will fix it.
niko
Re: CAL_ID FBBT057
Post by niko »
mikel wrote:you can send me the pcm and I will fix it.
I restored the original map by ford service center and my car is fine now .... I think that the predator may have problems!
according to your experience, the predator can give this kind of problem, or more simple and that the problem is on my PMC?
the car is in italy and this is a big problem :oops:
Return to “Predator Ford Gas”
