Siverado pinging...5.3L
Roadrage68
Post by Roadrage68 »
I just purchased another Silverado with the 5.3L and moved my Predator from my other truck to this one.
So my new truck pings when I give it gas under light load just before it downshifts. BTW it has a single in dual out Flowmaster and a CAI (Not sure of brand right now)
So what I did was:
1. Install 87 Octane tune and data log a run on the freeway in top gear, about 2200 rpm, and about 70mph... DSLogRedux said -1% Injector Slope. So I modified the tune -1%.--------Seems like the ping went away (hard to tell with my wipers wiping so frantically.. lots of rain)
2. Ran another log in 3rd gear, 2400 rpm, 55mph...DSLogRedux said +3% Injector Slope. Did nothing
3. Ran another log at 4th gear (top gear), 2100 rpm, 68mph... DSLogRedux said +1% Injector Slope... This would put me right back where I started..
What am I doing wrong? What should I do next? What are the best conditions (gear, rpm, etc.) for logging?
I just want to get rid of the pinging, can somebody help me out?
PS. The gas is currently 87 octane from Costco.. I added a 108 octane booster.. and a small bottle of LucasOil Fuel system treatment added as well.
Re: Siverado pinging...5.3L
sure its not going in and out of MDS?
its not likely to knock at light throttle, and if it is, you can see it in the logs ;)
Roadrage68
Not sure what MDS is and what am I looking for in my log regarding KR? Some of the readings seemed erratic, to me at least.
Roadrage68
If you mean DoD by MDS it is turned off... BTW I have a 2007 NNBS Silverado.
Roadrage68
OK.. so I cleaned my MAF yesterday and also tightened all the connections on the CAI, they were all loose. Maybe thats why my logging data seemed erratic...
So I made another logging run, and DSLogRedux said I need to Adjust Injector Slope +7%... I modified my tune and I'll rerun it tonight.. Does this sound correct to you guys?
makes sense anyhow :)
Roadrage68
Should I reset my computer and relog or just try the +7% and relog?
try the 7% first.
