Intake Air Temperature gauge not reading right
maxwellmurder
i have my virtual gauges set up. the intake air temperature gauge range i have set for 0-175. it works great until it gets colder than 32 degrees F. after that it just starts showing negative temps. like 30 degrees is showing as -2 degrees. any ideas on how to get it to display the correct temp?
srt8-in-largo
Re: Intake Air Temperature gauge not reading right
I take it that you set the range manually for this parameter. If so, I also have problems with a couple fo parameters when setting the range. Sometimes when I do that, the range does not "stick".
