help! data logging reading
clemsontigers000
Post by clemsontigers000 »
This afternoon I decided to run the truck to test the knock. I have posted the recording of the knock and would like to have someone to please look at the recording and provide some feedback for the recording. At the begining of the recording, the first run was a dead stop WOT run. After that run, I u-turned and throttled hard and got the highest ST knock thus far (11.00 degree.) The next run was again from a dead stop with WOT. The remaining of the recording (about the last seven minutes or so) was just blipping the throttle on the interstate.
I did a recording earlier today just watching ST and LT knock, no RPM. During that run I got a max of 1.5 LT knock 4.0 ST knock.
Overall I am wanting to know the your interpretation of the whole run I have posted and what you believe I should do to help get the knock down or eliminated.
Thanks!
datalog1 11-22-12 @ 1800.log
(480.53 KiB) Downloaded 222 times
clemsontigers000
Re: help! data logging reading
bump bump. any help?
clemsontigers000
bump again!
Mike is at the PRI show. I have no idea when he'll be back. Most likely Monday.
clemsontigers000
ok thanks for that info. ill bump it again next week sometime.
clemsontigers000
bump bump. any help
add some fuel in the rpm range where the knock starts...
