no power to handheld
elecman
Post by elecman »
Predator handheld wont power up when plugged into my vehicle. Any thoughts why this might be happening?
Re: no power to handheld
check your cig. lighter and aux power fuses... cuz that's where the obd port gets its power from, so if a fuse is blown, there will be no power to your obd port.
you can also check it in any other vehicle - plug it in to another vehicle's obd power and see if it powers up... if it does, then it's a fuse issue with your car... if it does not, then it's an issue with the predator itself and you'll need to contact tech support monday...
