C6 Corvette A6
Jruss
Post by Jruss »
My firend ran his 07 C6 @ 12.1 @ 117 for three runs with his vararam, he took it off and put on my halltech and loaded the stock diablo tune, next run he ran 11.8 @123. Coincidence? Well, he now runs a halltech....
This would mean he had one hell of a fresh air opening for the HallTech of which is also a positive for the Vararam.
What have you done to get the outside cooler air to your HallTech?
Also, please comment on my last log.
2006 Victory Red 3LT A6, Magnetic Ride, Corsa Sports and Hall Tech Stinger.
jsk06c6 wrote:
mikel wrote:Guys, i have seen way too many Vararam equipped cars run way too good at the track to even consider using anything else.
My buddies bone stock untuned 02 Z06 ran 118mph with a cat back and a vararam! I saw one add 3.5mph to a bolt on C5 as well,and over 3 mph on a stock C6. Tuning for the Vararam is no biggie, you just want to add a bit of fuel up top to take advantage of the improved, unrestricted airflow.
Great, so you run rich at high rpms until 80mph which is where the backpressure of the vararam comes into play.
I just don't understand why people belive this stuff about the vararam, if it was so great the manufacturers would already be doing it.
The numbers that really went down were his 60 and 330ft times, proving that something just wasn't right at low vehicle speeds.
You confused me a bit here...did he have the Diablo tune in the car with the Vararam as well, cause if not its not a fair comparison.
Also...whoah...what else was done to this car? 123 is serious trap for a bolt on C6. Impressive for sure....
PICTUREMAN
Re: Today's Log
Post by PICTUREMAN »
jsk06c6 wrote:
Jruss wrote:Made the adjustments and here is what I came up with today.
Looks like another-1% on the LTFT's.
Based upon your log yes, but, your RPM's are pretty low, do another run in a lower gear if you have a manual, or one of the other drives ( i dont have the auto so i dont know which ), to get your RPM's up.
Hey question for you guys. I have an 07 Vette w/paddles and only mods are Corsa sport duel exhaust & duel cone K&N filter.
I've ordered the Diablo u 7194 but getting second thoughts :? about even using it after all the hastle & problems people have.
So do you guys really like it & think it's worth the $$$$, & time to figure out & tinker with.
jsk06c6
Post by jsk06c6 »
mikel wrote:You confused me a bit here...did he have the Diablo tune in the car with the Vararam as well, cause if not its not a fair comparison.
Yes, but he had it adjusted to be a little more rich to compensate for the lean condition the vararam would produce at high speeds. We just got rid of his PE adjustments when we installed the halltech, and propped open his shroud to let the air in from below.
He has headers, no cats, corsa in the rear, thinks thats about it.
But my set-up is yielding 11.62 @ 127 :lol:
2006 Victory Red LS2 1LT M6, Halltech Stinger, 4" round B&B Bullets, B&B x-pipe, CCA Catch Can, Aluminum Throttle body spacer, Z51 sway bars
    jsk06c6
    Re: Today's Log
    Post by jsk06c6 »
    PICTUREMAN wrote: Hey question for you guys. I have an 07 Vette w/paddles and only mods are Corsa sport duel exhaust & duel cone K&N filter.
    No problems here, its a good start until you start ripping into the engine or go forced induction.
    But, I have a M6, so I don't have as many problems with TM like you have. The canned tunes are suppose to help you a bit, but I've driven a few auto's and to be honest, i hate the C6 with an auto, TM kills you. Your probably better off getting a tune from a professional tuner using other software options.
    Jruss
    RE: Re: Today
    Post by Jruss »
    I've ordered the Diablo u 7194 but getting second thoughts about even using it after all the hastle & problems people have.
    I have the A6 and I'm pleased with my purchase and seat of the pants improvement is there.
    With the promise of TM on the way (Some Day) ??? This unit should be well worth the investment.
    If TM tuning wasn't in the works, I would have given second thoughts to purchasing the DiabloSport for my A6!
    Hopefully we will see TM soon :D !
    Re: Today's Log
    Yeah, where do you see people having problems?
    This is a great tool, and you will truly enjoy the tunes on your car.
    jsk06c6
    Post by jsk06c6 »
    Jruss wrote: This would mean he had one hell of a fresh air opening for the HallTech of which is also a positive for the Vararam.
    Goto corvetteforums or digital.corvettes and do search for the "free cool air mod". basically you pull two fasteners and prop open the shroud, it hangs down about 2-3 inches and pulls in a whole lot of air.
    It makes the engine compartment a bit dirty, so you have to keep up on that but the filter doesn't seem to pick up much of that, my guess is the fact that the bottom of the filter isn't breathing like the vararam. Which get's so dirty in a couple weeks it needs to be cleaned a lot.
    As for your log, your LTFT's are good, your done with that.
    Jruss
    Post by Jruss »
    I live within a stones throw of Eckler's so I went over and looked at the Vararam. The quality is somewhat less then I expected especially thefit of the filter box.
    Thinking about the Vette-Air type pickup of which is similar to the Vararam pickup and constructing a top panel to close off the filter area from the engine bay. Finding the material to match the or come close to the present material in the engine department is my problem right now.
    jsk06c6
    Post by jsk06c6 »
    Jruss wrote: I live within a stones throw of Eckler's so I went over and looked at the Vararam. The quality is somewhat less then I expected especially thefit of the filter box.
    yea, I thought it was pretty low quality myself.
    I was thinking of the vette-air scoop too, which works pretty well with the z06 intake, but again I've heard of some some dirt issues with the filter on that set-up. I'll probably stick with the halltech, but still might add the vette-air scoop, right now the cold air works fine.
    Been looking for a option to close off the air filter from the rest of the engine compartment as well. Seen quite a few different set-ups, but so far they only seem to minimize the dirt coming in, they all leak to some extent. Looking to add the lpe ram air hood anyway, so I'll have to just live with the clean-up.
    Jruss
    Post by Jruss »
    I agree Mike! The tool is about as much bang for the buck as you can get. I'm very pleased with my purchase.
    The DiabloSport is a fun tool !
    I figure I'm getting most of what I could get from a Dyno tune without the wear and tear on the car and my nerves. Plus the ability to check for codes, Real time data loggng and the ability to do some tweaking anytime I choose under actual driving conditions.
    Here is a question I asked else where.
    Is TM reduced in the C6 A6 tunes and is the delay when you go from park to drive removed?
    Am I right in assuming that the Diablosport tunes are the latest factory tune with performance improvements?
    The tune is always based on whatever tune is in the PCM form GM.
    The TM is reduced.
    Not familiar with any delay in 'D' though....
    Return to “Predator GM Gas”
